Configures the VLAN info portion of the circuit ID of a VLAN.
vlan_info | Specifies the circuit ID VLAN information for each VLAN in the format of VLAN Info-Port Info; maximum length is 32 bytes. |
vlan_name | Specifies the VLAN for which DHCP should be enabled. |
all | Specifies all VLANs. |
dynamic | Configuration options for dynamically created VLANs. |
The default value is the ASCII representation of the ingress VLAN‘s ID.
This command allows you to configure the VLAN information portion of the circuit ID of a VLAN. The VLAN info is a string of characters of up to 32 bytes in length, and is entered in the format of VLAN InfoPort Info. When a specific value is not configured for a VLAN, vlan_info defaults to the ASCII representation of the ingress VLAN‘s ID.
Dynamic VLAN option added in ExtremeXOS 30.2.
